Civil 3D Forum
Flippable label
6 REPLIES 6
csevers
1207 Views, 6 Replies
Flippable label
I've got an alignment label style I created and I would like to be able to flip the label over my alignment if necessary, similar to station labels. I can't find anywhere in the label style composer were I can specify this option.
Chris Severs, PE
Windows 7 Enterprise SP1 64 bit
64.0 GB RAM
Intel Xeon E5-2650 v3 @ 2.30GHz
NVIDA Quadro M4000
Civil 3D 2014
6 REPLIES 6
owenmull
in reply to: csevers
Is this what you're seeking?
-Owen
Windows 7 x 64 bit
Civil 3D 2017
______________________________________________________________
Usually, I find that the problem is between the keyboard and the chair.
csevers
in reply to: owenmull
Yes, exactly. I would like to be able to select that option for a label that I create.
Chris Severs, PE
64.0 GB RAM
NVIDA Quadro M4000
Civil 3D 2014
Bill_Myron
Alignment labels are part of a set.
If you want to have them ALL on one side, adjust the rotation of the label components in the editor.
If you want only a select FEW then h
old Ctr (Control) and select the label. You will then have the option to flip it.
csevers
in reply to: Bill_Myron
I think you're thinking of the station and geometry labels, I'm talking about Station Offset type alignment labels. It's kinda a mute point as I've made 2 additional styles to dispaly on the "flipped" side of the alignment, but i'm curious if there's a way to incorporate the same functionality as the station and geometry labels into a station offset label.
Chris Severs, PE
64.0 GB RAM
NVIDA Quadro M4000
Civil 3D 2014
Jeff_M
No, there's not. You just need to have the different styles as you've done.
Jeff_M, also a frequent Swamper
csevers
in reply to: Jeff_M
Chris Severs, PE
64.0 GB RAM
NVIDA Quadro M4000
Civil 3D 2014
Rail Community
