I've got an alignment label style I created and I would like to be able to flip the label over my alignment if necessary, similar to station labels. I can't find anywhere in the label style composer were I can specify this option.
Solved by Jeff_M. Go to Solution.
Alignment labels are part of a set.
If you want to have them ALL on one side, adjust the rotation of the label components in the editor.
If you want only a select FEW then hold Ctr (Control) and select the label. You will then have the option to flip it.
I think you're thinking of the station and geometry labels, I'm talking about Station Offset type alignment labels. It's kinda a mute point as I've made 2 additional styles to dispaly on the "flipped" side of the alignment, but i'm curious if there's a way to incorporate the same functionality as the station and geometry labels into a station offset label.
