Civil 3D Forum
Flip Dimension Arrow
3 REPLIES 3
jamesmac1200
4238 Views, 3 Replies
What is the process to flip dimension arrows in 2010/2011. In LDD, all I had to do is select the dimension, right click and the option was available. I don't see it in 2011. Thanks.
Civil 3D 2016 SP4
Intel Xeon CPU E5-1620 v3 @ 3.50 GHz
40GB RAM
64-Bit
Window 7 Professional
3 REPLIES 3
OMCUSNR
in reply to: jamesmac1200
I'm not sure what you mean by "flip the dimension arrows"?  Picture?
Reid
Homebuilt box: I5-2500k, MSI P67A-GD65, 12gig DDR3 1600 ram, ASUS ENGTX460 Video card, WD Velociraptor WD4500HLHX HD, Win 7 64 pro.
mathewkol
It's a CUI thing.  The AutoCAD contextual menu is defined differently for DIMs that the Civil CUI.  You can copy it from the ACAD partial CUI.  But you have to copy it to the main Civil.cuix file.  I haven't found a way to do this with my partial CUI.
Or typw the command:
aidimfliparrow
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
jamesmac1200
in reply to: mathewkol
Matt,
I haven't tried the CUI, but the command worked exactly as I wanted. Thanks for the quick response.
Civil 3D 2016 SP4
40GB RAM
64-Bit
Rail Community
