Civil 3D Forum
Flatten point styles to elevation
10 REPLIES 10
Message 1 of 11
IanMcClain
1978 Views, 10 Replies
Is there a way to change all your point styles display mode (flatten to elevation, use point elevation, or exaggerate elevation) at once? I don't mean make a new style and then apply it to all points: I want to systematically change it for all my current point styles.
Ian McClain
10 REPLIES 10
Message 2 of 11
sboon
in reply to: IanMcClain
Nope.  Point styles have to be edited one at a time.
Steve
Expert Elite Alumnus
Message 3 of 11
Jeff_M
in reply to: sboon
Unless you know someone who can whip up a quick lisp to do it for you. 🙂 See attached lisp file.
Message 4 of 11
nostupidquestions
in reply to: Jeff_M
dang! thanks!
Intel(R) Xeon(R) W-2245 CPU @ 3.90GHz 3.91 GHz
64 GB RAM
C3D 2023.2
Message 5 of 11
IanMcClain
in reply to: Jeff_M
Awesome! Thanks!
I really need to learn LISP 🙂
Ian McClain
Message 6 of 11
PPanek
in reply to: Jeff_M
Jeff,
Thank you for very useful SETPOINTDISPLAYMODE.lsp code. There should be a way of global editing of other Point Style settings e.g. "leader stops at marker: no" or Orientation Reference etc.
I have a problem though: after successfully executing SETPOINTDISPLAYMODE.lsp for several times, it stopped working:
The error message is as follows:
Command: SETPOINTDISPLAYMODE
; error: Automation Error. Problem in loading application
Any idea how to fix it?
Thank you,
Przemek
Message 7 of 11
DonMBW
in reply to: Jeff_M
Any chance you have a Civil 3D 2015 Version of your setpointdisplaymode.lsp?
Don
Message 8 of 11
GTVic
in reply to: DonMBW
I've updated the file to support up to Civil 3D 2018. Hope that is okay with Jeff M.
Message 9 of 11
Sir, Is it possible to change all point elevation as flatten, if I use the lisp.
Message 10 of 11
GTVic
in reply to: GTVic
Updated for 2019
Message 11 of 11
GTVic
in reply to: nizamthonichal
The lisp changes the display of the points not the actual elevation of the points.
If you have cogo points in the drawing (not in survey database), you can use the panorama, Ctrl-A to select all points, right-click the elevation column header and select Edit ... and change all to a single elevation. This permanently alters the point elevations.
Another option is to select a point group in the prospector, edit the properties of the group and under overrides, check the Point Elevation box and set an elevation. This is an override so you can go back to the original elevations.
If the points are in the survey database you can use the SDB points list, Ctrl-A, right-click Edit ..., etc. and then hit the Save button. Again, this is a permanent change.
Rail Community
