AutoCAD Civil 3D General
*Expert Elite*
Neilw
Message 1 of 4 (158 Views)
Finding drain pipe daylight locations
158 Views, 3 Replies
08-21-2013 04:11 PM
Here is a challenge I'm needing to solve.
I need to rough in a drainage pipe network that connects several structures around a site. The pipe inverts need to be 6.5' below the finished floor of each unit and must maintain a minimum 2% slope. The network needs an outfall at some undetermined point on the site. The pipes must follow some existing roads, so they are not interconnected directly to each structure.
How can I go about determining the potential outfall locations?
Neil Wilson (a.k.a. neilw)
Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
WIN 7 64 PRO
HP Pavillion h8xt, i7 2600, 12 GB
RADEON 6450, 1 GB
http://www.sec-landmgt.com
*Expert Elite*
troma
Message 2 of 4 (105 Views)
Re: Finding drain pipe daylight locations
08-22-2013 01:30 PM in reply to: Neilw
Start with the worst case scenario: the lowest unit. Go down your depth, then start sloping down. Maybe make a surface sloping down 2% all directions for a rough idea. Then do a mindistbetweensurfaces to your original ground to see if you have any outfalls.
Credit where credit is due! Give kudos or accept as solution whenever you can.
*Expert Elite*
Neilw
Message 3 of 4 (97 Views)
08-22-2013 02:39 PM in reply to: troma
Thanks for replying. Starting at the lowest unit seems to make sense but the furthest unit is also critical if there is not enough drop at 2% for it to daylight.
After spending some time on this I don't see any other way than trial an error.
WIN 7 64 PRO
RADEON 6450, 1 GB
*Expert Elite*
troma
Message 4 of 4 (77 Views)
08-23-2013 05:29 AM in reply to: Neilw
I'd say you're right. Too many parameters and options to totally automate.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
