AutoCAD Civil 3D General
Valued Contributor
Postmaster_G
Message 1 of 4 (328 Views)
Find path of determined slope along a surface
328 Views, 3 Replies
10-25-2013 01:27 PM
So I am trying to draw an alignment for a road.  I want the alignment to represent the outside of the curve as the road climbs up and around a mound. Is there not way to do this in Civil 3D?!?
I have read this post
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/How-to-draw-a-3d-pline-at-a-designed-grade-on...
and this post
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/Feature-Line-at-Grade/m-p/1533814/highlight/t...
and now I am thinking I will have to do this manually, extract contours, and trim/extend my way to victory...
I really would like to have this in a dynamic situation so I can make adjustments.  Also, it would be adventageous to have the line actually follow the grade so I dont have to add curves in etc later...
I do not have money to spend on an add on, I wish I did!
Valued Mentor
TerryDotson
Message 2 of 4 (291 Views)
Re: Find path of determined slope along a surface
10-26-2013 05:54 AM in reply to: Postmaster_G
For those that would consider an add-on, follow this link.
Autodesk Exchange Store - GradePoly
*Expert Elite*
Neilw
Message 3 of 4 (281 Views)
10-26-2013 07:59 AM in reply to: Postmaster_G
I've dealt with this scenario more than a few times. You won't find a dynamic solution. Terry's tool is probably the best option. Use it as a guide to layout an alignment. Once you have the alignment you can run the tool with different parameters to make adjustments.
Neil Wilson (a.k.a. neilw)
Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
WIN 7 64 PRO
HP Pavillion h8xt, i7 2600, 12 GB
RADEON 6450, 1 GB
http://www.sec-landmgt.com
Valued Contributor
Postmaster_G
Message 4 of 4 (234 Views)
10-28-2013 01:03 PM in reply to: TerryDotson
I appreciate this response, except I clearly state I do not have the money for this add-on.
When I do, I will most likely purchase this as it seems very useful.
Here is an idea.  I would pay twice as much for an add-on that would consider this situation:
...So I want my outside edge of road to ride the slope at x%.  I want my road to have a fixed width. I want the inside of the road to also be at x%.  I would like my minimum turning radius to be y-distance. Press go and it will give the required centerline and edges of road.
The cost of the add on being near 1% the cost of the program is not bad at all, 60 bucks is a bit steep for one feature though...
I wish guys like you worked for autodesk so this would just be in the program.  That or they should totally buy this from you (guess they are cheap like me)!
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
