Can you filter 3dpolylines to find which ones have a vertex at 0 elevation? I do not see the option in the Object Selection Filters dialog. We have several 3dpolys which would take a while to go through each vertex.
Mark Green
Working on Civil 3D in Canada
QSELECT>3d Polylines>Vertex Z=0
Mark Green
I usually just use a 3d view but was just seeing if there was a method through the Object Selection filter since it was a large topo.
The surface method of lookin at errant contours wasnt an option because the computer was not allowing a surface to be generated.
I dont know why I didnt check quick select. That is the quickest method, as you can find all errors at once.
Thanks for the responses.
