Hi there
I am trying to learn Civil 3D at the moment and was wondering if it would be possible to round the edges of the solid i attached as a .dwg file. I thought it would make sense to use the FILLET command but it didnt seem to work.
Thank you in advance.
I think you'd be looking for the FILLETEDGE command. See snip below. Since this is more of an AutoCAD related question, you might get a better response in the AutoCAD group. I don't know of any Civil 3D commands that work with solids.
Allen
Allen Jessup
CAD Manager - Designer
If your goal is to soften that "solid" surface, I guess you should not fillet it, but generate more dense contours, then recreate the surface.
