Civil 3D Forum
File in network deployment for 2012
8 REPLIES 8
Message 1 of 9
AllenJessup
607 Views, 8 Replies
I'm having trouble installing a  Hotfix for C3D 2012. The error I'm getting is that it can't find the file AeccCascade.cab. Autodesk Support says this is because the path to my deployment is broken and I need to reinstall C3D. However it looks to me that the path is OK. I've checked the registry and did a Repair with no problem.
Can anyone that has a Civil 3D 2012 network deployment find that file there?
Allen Jessup
Civil 3D 2012 SP 2.1
Dell Precision T7400, Xeon CPU 3.16 GHz
Win 7 Pro, 64-bit,12 GB RAM, Nvidia Quadro FX 4600
Allen Jessup
Engineering Specialist / CAD Manager
8 REPLIES 8
Message 2 of 9
jmayo-EE
in reply to: AllenJessup
Hey Allen. If this is a net install I think you may need to confirm the deployment ini file has the correct paths.
See the attachment for the location of this file. I also opened up the ini file to show you where to look for the paths. There should be two. I highlighted the first one. 3 lines down is the second. Confirm that these are the only erroneous paths in the ini.
John Mayo
Message 3 of 9
jmayo-EE
in reply to: jmayo-EE
Oh sorry if you got though a repair the ini file should be good...
John Mayo
Message 4 of 9
AllenJessup
I also started a reinstall from the shortcut to the deployment. I canceled it as soon as I was sure it was running.
Thank for the reply.
Allen Jessup
Allen Jessup
Message 5 of 9
I have a network deployment. I don't have that file.  That said, I did not install that hotfix as I don't use network licensing.
Lisa Pohlmeyer
Civil 3D User
Website | Facebook | Twitter
Message 6 of 9
jmayo-EE
Hi Lisa. You should have an ini file for the admin image install. The name of that ini file is the deployment name we provide when creating the deployment. Sorry for the confusion. 😮
John Mayo
Message 7 of 9
Yep, I know that.  I create a deployment on my local drive then modify the ini file to the path on the network (since the deployment creation won't allow for network paths for the image creation).  What I got from the OP is that perhaps the issue stems from the fact that he uses a License manager.  I don't, we have standalone licenses.
Maybe I missed something.
Lisa Pohlmeyer
Civil 3D User
Message 8 of 9
You're not missing anything Lisa. Autodesk is stumped too!
Allen
Allen Jessup
Message 9 of 9
AllenJessup
I've solved the issue that prompted me to ask this question. For anyone who is interested the resolution is in THIS thread.
Allen Jessup
Allen Jessup
Rail Community
