AutoCAD Civil 3D General
Valued Contributor
Message 1 of 4 (1,302 Views)
Accepted Solution
File Size Increases After Save
1302 Views, 3 Replies
02-11-2011 03:03 AM
I am using AutoCAD Civil 3D 2009.I have a project files suddenly file size becomes @ 10 MB after saving. Even Titlblock size is 7 MB.
I had installed a latest update over my system as well i tried to clean a file as per below thread.
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/File-size-and-performance-issues/m-p/2800660#M139135
After doing this file size reduced to KB. But if open it again and saved then file size go to MB.
Is there anyway to fix it??
We need to fix it asap..so plz help me.
Thanks in Advance.
Product Support
Message 2 of 4 (1,290 Views)
Re: File Size Increases After Save
02-11-2011 05:17 AM in reply to: YM_99
Hi YM_99-
Did you install that Hotfix Almas mentioned in his post? If not, that would be ths first thing I would suggest trying. Here is the link: http://usa.autodesk.com/getdoc/id=DL15412532
Hope this helps!
Seth Hall
Product Support
GCSO - CSS - FTS
Autodesk, Inc.
Being Civil
Being Civil Twitter
Being Civil Facebook
Valued Contributor
Message 3 of 4 (1,232 Views)
02-14-2011 09:12 PM in reply to: SethHall
hi Seth...
thanks a lot....it solves the issue....
New Member
Message 4 of 4 (791 Views)
How is size determined when a file is saved?
09-24-2012 12:20 PM in reply to: YM_99
My daughter is an artist and loves this software.
She is being asked to creat art for posters at school but when she saves the files they are too small to be used.
How does she save files so they are as large as possible?
Is there setting preferences or saving options that make larger size saves possible?
WHat do you reccomend she do to save the files ina large as possible format.
Thank you.  -Brian
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
