Civil 3D Forum
Figure Styles Multi Lines
2 REPLIES 2
DawnAW
317 Views, 2 Replies
Good morning,
I am using AutoCAD Civil 3D 2011.  I am wondering if there is a way to assign an mline to a figure style in the Figure Prefix Database.  Ultimately I am trying to create storm drains that have a width automatically (ex. 12" SD would come in at 12").  Right now I have a single center line that comes in and I manually offset the line to create a width or I place an mline over the center line.  It seems there ought to be an easier way.  Am I on the right track or is there another way?
Thanks for any help!
2 REPLIES 2
awood
in reply to: DawnAW
One way might be, when coding in the field, use a horizontal offset. That will draw your parallel figure.
You could also add this manually to the data file (ASCII file) and then re-import.
Code the centerline like B 12 SD H.5 H-.5 maybe...
HTH
AWood
rl_jackson
in reply to: DawnAW
Well you could convert your Survey Figure to a Pipe Network, basically setting styles just like the Engineering side does.
Personally I have always been a fan of Linetypes with Text for these situations on the the Survey side.
Rick Jackson
Survey CAD Technician VI
Rail Community
