Good morning,
I am using AutoCAD Civil 3D 2011. I am wondering if there is a way to assign an mline to a figure style in the Figure Prefix Database. Ultimately I am trying to create storm drains that have a width automatically (ex. 12" SD would come in at 12"). Right now I have a single center line that comes in and I manually offset the line to create a width or I place an mline over the center line. It seems there ought to be an easier way. Am I on the right track or is there another way?
Thanks for any help!
One way might be, when coding in the field, use a horizontal offset. That will draw your parallel figure.
You could also add this manually to the data file (ASCII file) and then re-import.
Code the centerline like B 12 SD H.5 H-.5 maybe...
HTH
AWood
Rick Jackson
Survey CAD Technician VI
