Civil 3D Forum
Figure Stepped Offset.. an easier way?
2 REPLIES 2
REGifford
261 Views, 2 Replies
My question seemed simple enough but we have not been able to find an answer yet, so maybe someone here can help us out.
We are currently running Civil 3D 2007, with 08 on the way. We have a field crew located top back of curb. When we bring in the fieldbook file is it possible to have a figure line created along the back of curb (this we get) BUT to automate the stepped offset command to "build" the gutter line and edge of pavement based on design standards? (IE. Gutterline = 0.5' offset with -0.5 vertical and Edge of Pavement = 2' offset with -0.4 vertical change) I have tried working with Corridors and Assemblies, but I may be doing something wrong. I know some other programs will do this (Terramodel, Carlson).
2 REPLIES 2
in reply to: REGifford
I have the same question. I have tried "format" in "Description Key Sets" { $ H+ .5 H+.01 V-.5 H+ 2 V+ .08 }but it does not work. This will work when pasted in FKB after code and brought into drawing. {H+ .5 H+.01 V-.5 H+ 2 V+ .08}. Lines offset great in Civil 3D
mathewkol
This is best done by the surveyor. When they're shooting the first gutter point the code would be:
GL H0.5 V-0.5 H2.0 V0.4
Then shoot the gutter using only GL as the code.
When you're done with the gutter the code is GL SO (stop offsets).
This will give:
One line to the right at .5 feet right and .d feet lower
One line to the right at 2 feet right and .4 feet higher.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Rail Community
