Civil 3D Forum
Fields within Labels
6 REPLIES 6
jamesmac1200
597 Views, 6 Replies
Hopefully one of you pros can assist me on this one. Is there a way to add a field within a label style? I made a custom alignment label and I would like to add a field that references a sheet (I'm using SSM) i.e. "See Sheet 1-2". Thanks.
Civil 3D 2016 SP4
Intel Xeon CPU E5-1620 v3 @ 3.50 GHz
40GB RAM
64-Bit
Window 7 Professional
6 REPLIES 6
Joe-Bouza
in reply to: jamesmac1200
No can do. sorry its not supported. you'll need to ad a seperate MTEXT with the field
Your Name
emelendez
Well, in a round about convoluted way you can get what you are looking for, but it will not be linked to the SSM. You can create a reference text object within the alignment label style that will reference the description of a cogo point within the same drawing. In the screen capture attached, you will see a object "A" is a cogo point with the description reading "sheet 1-2" and in the alignment label at the bottom you will see where it matches the description of the cogo point. That is as close as I can come up with to getting what you need.
No it's not linked to the SSM but all references are linked to a cogo point description. all you need to do is manage your descriptions of your cogo points. One neat feature of the "reference text" of the label style is that you can change what object is being referenced in each label independently through the properties dialog box.
Edwin Melendez
AutoCAD Civil 3D 2013 Certified Professional
Certification No. 00319327
tcorey
in reply to: emelendez
Here's another example of a creative way to get Civil 3D to do things is doesn't do out-of-the-box. Thanks for posting, emelendez.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
jamesmac1200
Thanks for the response. I'll check it out tomorrow.
Civil 3D 2016 SP4
40GB RAM
64-Bit
Joe-Bouza
in reply to: tcorey
it is nifty, but a peice of mtext inserted near the 3d label would be dynamic to SSM. For me I'ld rather not have to wory about updating a point list to sync with a drawing list. But it is creative
Your Name
emelendez
@TCOREY & JAMESMAC1200- Your Welcome
@JOE-BOUZA- I agree with you. I would rather have a piece of text linked to the sheet set manager. The more custom you create things that are work arounds, the greater the risk that someone will come behind you and not understand what you did and just mess things up.
Edwin Melendez
Rail Community
