AutoCAD Civil 3D General Discussion
mikepo
Message 1 of 1 (89 Views)
Fields don't update on print
89 Views, 0 Replies
10-22-2013 05:28 PM
We have had a couple issues when printing drawing using Sheet Set and Page Setup Overrides.
When the sheet is printed, our detail callouts which reference sheet views have hash tags.
If you open the drawing, the fields are showing correctly.
If you print the drawing directly within the sheet, the field values print correctly.
If I change the "FIELDEVAL" setting in the drawing to 27, and then priint using Sheet Set, the filelds values will print.
It's only happened in a couple of Sheet Sets, but it very disconcerting because it is sporadic.
It doesn't happen with every drawing in a Sheet Set.
Any ideas??
Thanks.
Mike Porter
www.ppeng.com
Civil3D 2014 SP2
Win 7 Professional - 64-bit
HP Z400
Xeon W3550 @ 3.07Ghz
24GB of RAM
Nvidia GeForce GTX 760
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
