AutoCAD Civil 3D General
Active Contributor
Message 1 of 5 (270 Views)
Feature lines in corridor not matching up with assembly changes
270 Views, 4 Replies
06-28-2013 09:28 AM
Civil 3D 2013. I have a 7km strech of road with 3.5 meter lanes, 2.5 meter shoulders and 0.5 meter for rounding. There are small sections along the road where I want to pave the right shoulder making the right lane 6 meters. To do this I copied the assembly used for the main strech, deleted the right shoulder, and changed the width of the right lane to 6 m. To apply the new assembly I am just adding redions within the corridor properties and selecting stations where I want the wide lane. For some reason, the left side of the road shifts in a bit where the wide lane sections are. The left side of the assembly is exactly the same throughout the whole corridor, and I have only used 1 baseline. The left side shouldn't change at all so I don't know what's going on.
Also, some sections the lanes match up at the transition and some don't. In the picture the lane stays together near the bottom when it widens, but doesn't at the top.
*Expert Elite*
TRogers
Message 2 of 5 (256 Views)
Re: Feature lines in corridor not matching up with assembly changes
06-28-2013 11:14 AM in reply to: nathan07
Instead of using multiple assemblies, use the same one and target a polyline or feature line that will follow the lane widening.
If the issue was resolved by this method, please click on "Accept As Solution"
*Civil 3DJ*
Todd Rogers
Visit my blog here.
Active Contributor
Message 3 of 5 (253 Views)
06-28-2013 11:31 AM in reply to: TRogers
The issue I'm having by doing that is that the rest of the subassemblies
still apply. So the whole right side of the corridor shifts outwards when
all I want is the lane itself to widen eliminating the 2.5m shoulder. So the
when I target a feature line it widens the lane correctly, but is also
widens the shoulder and the 0.5 m rounding and daylighting.
*Expert Elite*
sboon
Message 4 of 5 (241 Views)
06-28-2013 12:06 PM in reply to: nathan07
I can't think of an obvious reason why edits on the right side of an assembly should affect the left side.  Based on the description the only thing I can think of is that the subassemblies aren't connected properly within the assembly.
Can you upload the drawing for us to look at?  If not the whole thing then just your alignment, prpfile, assembly and the corridor would probably be enough.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Valued Contributor blt
Valued Contributor
Message 5 of 5 (225 Views)
06-28-2013 03:41 PM in reply to: nathan07
Put in two targets one for the shoulder and one for the edge of pavement.  Keep the two separated by a really small distance where you wanted the shoulder eliminated.  You will still have a shoulder but you can make it a really small distance.
Bryan Thorp
Civil 3D 2013 SP1
Dell T3500 Workstation
Intel Xeon E5630 @ 2.53 GHz
12 Gig of RAM
Nvidia Quadro FX3800
Window 7 x 64bit OS
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
