Civil 3D Forum
Feature line moves when section with projected object is moved
2 REPLIES 2
rdlongbow
212 Views, 2 Replies
C3D 2012 SP2.1 on Win7-64
I have a marker on a cross section that was projected from a short feature line that I created from a 3DPolyline.  If I move the cross section (they never come in correctly, right?), the feature line moves too. If I use a 3Dpoly, this doesn't happen. Only went to the feature line because for some reason, when I went to Project Multiple, the 3Dpolys weren't picked up.
Now I wondering if I've moved feature lines on other projects where I have moved the sections. Could be a real problem. Most of those, though, had a mix of feature lines and 3Dpolys, so they would only be partially messed up! Hopefully, I moved the sections before doing the projection.
2 REPLIES 2
mathewkol
in reply to: rdlongbow
You are moving the seciton views by a window.  Do not move them this way.  Select ONLY the view with the pick button.  If you need to select a bunch all at once, use the quick select tool.  But never move them (or especially erase them) by a window.
[If I move the cross section (they never come in correctly, right?)]
Mine always come in correctly.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
rdlongbow
in reply to: mathewkol
I have been moving them by Window, so that could be it.
OK, so it is possible to get cross sections to end up all the way in the frame. The secret is?????? Some of the text alway seems to overhang the frame.
Rail Community
