Civil 3D Forum
Feature line in Autocad 2012
3 REPLIES 3
jnjhuz
232 Views, 3 Replies
I have a feature line that I want at a constant elevation and it is going to be part of a new surface. I want to grade 4:1 to the eg surface. The feature line is interacting with the eg surface in that it is geting more elevation points. I want it not to interact with the eg except to grade to the surface. Do I want the eg surface on the same site or a different site as my features lines? If it is on a different site will it still grade to the eg. How can I put my eg on a new site. I can't find what site it is on?
3 REPLIES 3
tcorey
in reply to: jnjhuz
Surfaces are not on sites.
If you created your feature line from objects, and you told it to Assign Elevations, there was a check box to Insert intermediate grade break points. This will add more elevation points along the feature line.
Tim
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
owenmull
in reply to: jnjhuz
Feature lines of the same Site will interact with each other, meaning that two feature lines at different elevations that "intersect" in plan view will interact with each other. As you saw, the most recently edited feature line holds. So, at this "intersection," the first feature line behaves as if it was "stapled" to the most recent one. To avoid this, place the second feature line in it's own Site, reset your elevations, and then simply grade to surface.
As tcorey stated, surfaces are not contained in Sites. Sites contain Alignments, Profiles, Feature Lines, Grading Groups, and Parcels.
-Owen
Windows 7 x 64 bit
Civil 3D 2017
______________________________________________________________
Usually, I find that the problem is between the keyboard and the chair.
jnjhuz
in reply to: owenmull
Thanks. This is what was happening. In the end I did need them to react to
one another. But I now understood what was happening.
When I graded the proposed contour/feature line to the surface I got a
strange jag in the daylight. When I swap a tin line under the daylight the
jag goes away and shows up one or two places elsewhere on the daylight. Have
you ever had this problem? I'd send a picture but I "fixed" it by not
grading that small piece.
Rail Community
