Civil 3D Forum
Feature line - convert elevation point to PI
4 REPLIES 4
JeffPaulsen
2417 Views, 4 Replies
Is there a way to convert a feature line elevation point to PI?
My objective here is to delete all the elevation points except one. It would be time consuming to pick each elevation point and delete them individually (in this case there are about 15 but sometimes there are more). I want to use the delete all option but keep one one of them. If I can convert that one into a PI I could then quickly delete the remaining elevation points.
Jeff Paulsen
Civil 3D 2020.4 | Win 10 Pro N 64-bit
Xeon W-2223 @ 3.60GHz, 32GB Ram | NVidia Quadro P2200
4 REPLIES 4
AllenJessup
in reply to: JeffPaulsen
Not as far as I know. But there might have been something since 2012 that I don't know about.
What I would probably do is to mark the location of the one elevation point you want to keep, delete all the elevation points and then use the entity I used to mark the location to either insert an elevation point or a PI.
Allen Jessup
Allen Jessup
Engineering Specialist / CAD Manager
jmayo-EE
I have wanted to do this soooo many times...
The other option is to break the FL at the Elv Pnt but this will wreck havoc on any labels if you have them.
John Mayo
JeffPaulsen
in reply to: AllenJessup
Thanks Allen. I just drew a line to the elevation point to "mark" it, deleted all the elevation points, then added a PI at the end of the line. I had been breaking the feature line and joining it back up like John suggested but as he mentioned that messed up any labels I had on the feature line.
Jeff Paulsen
jmayo-EE
I just ignore labels until the end because the labels are shot if you break the FLine, add a PI, remove a PI, add an elv pnt or delete an elv pnt...Even if they're pinned the label stays and the leader moves...
John Mayo
Rail Community
