Civil 3D Forum
Feature line colours
3 REPLIES 3
onedayiwillbeaguru
880 Views, 3 Replies
Hi All,
When I insert featurelines from one drawing into another they lose their colour properties even though they are ‘bylayer’. i.e each feature line is a different colour but once inserted into new drawing they are all blue. If I click on the feature line it will show the correct colour in the properties block but not displaying as that colour.
Anyone know the reason for this and how I could stop it happening?
3 REPLIES 3
When you use the term insert, are you inserting them as a block. If so explode it and they should go to the correct layer.
Rick Jackson
Survey CAD Technician VI
tcorey
in reply to: onedayiwillbeaguru
Check your feature line styles.
Let's say your Feature Line Style is called MyStyle in both drawings, it might set the lines to Bylayer in one drawing and to Blue in the other. See the Display tab of the Feature Line Style Editor.
Don't explode the feature lines unless you absolutely must.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
troma
in reply to: tcorey
I think the explode remark can be explained thusly:
If your feature lines are individual feature lines, and say they are feature lines in the properties box when selected: don't explode the feature lines.
If you inserted feature lines as a block and they are still in that block, all together as one object that says it is a block in the properties box: explode the block.
If the feature line style is set to layer 0 and colour ByLayer, does the feature line take the colour of it's Object layer?  I'm not sure, but that's another possibility to look into.
Mark Green
Working on Civil 3D in Canada
Rail Community
