Civil 3D Forum
Feature Lines
2 REPLIES 2
186 Views, 2 Replies
Feature Lines
In LDT I would create 3D Polys (by Elevation) and select ".G" at the prompt
for points to select the AEC point object. That way the 3D poly will
automatically grasp the elevation, then I would type ".G" again to exit the
prompt. Is there a way to do this with feature lines in 3d? When I draw a
feature line and type .G or .P, nothing happens. Or do the points need to
be at actual elvations?
Thanks in advance.
2 REPLIES 2
In Civil 3D you should use the Transparent Commands; for example '_PO for points. It is more convenient to turn on the Transparent Commands Toolbar and use the transparent commands from those tools.
Feature lines have their own set of tools in a toolbar. Once you bring this toolbar up and see what is in it, you should have your answer.
Dan
Rail Community
