Feature Line / elevation question...
This might be more of a "wish list" question, I don't know.
Let's say I have two known end points with two known elevations. I want to put a feature line between the two, but there are a couple arcs involved. I am fine with the elevations being linear.
Is there a way to draw a feature line, and have it fill in the elevations in between automatically?
Thanks.
Solved by Joe-Bouza. Go to Solution.
wow, a feature line not showing still affects.
There is so much room for a 3rd party to do plan view ghosting of info a user would care about here.
Sinc?
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
You called it. I found a feature line that was used for utility location running right through this new feature line. The layer was turned off. So, it was suggested I put it on a different site, and this fixed that problem. The feature line still did not function properly as a breakline, though. I still got triangulation at one point.
