I am trying to create a feature line style that would include markers similar to minor stations of an alignment at the End Points and 1/4D, 1/2D & 3/4D locations. The thought is that I could use these on curb returns, and the markers would identify the locations we provide construction staking. Any ideas?
Thank you,
Mike Killion
I don't think that it can be done in the featureline style, but it seems like it should be possible to build a curve label style that would put markers at the points you want. You could also use reference text to add surface elevations to those points.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Thank you. I was able to use a curve label style to set marks at the Start, Middle, End and Radius Point, but not at the 1/4 and 3/4 points. Is there a way to set these? Once I have all the locations, I plan to use your suggestion to utilize reference text to get surface elevation labels.
Thank you,
Mike
Insert a PI at the mid point then 2 labels would give the 1/4 and 3/4
Joe Bouza
It took a while to figure out, but I've attached a drawing with a curve label style that includes lines to the BC, 1/4, 1/2, 3/4 and EC points.
It should be possible to edit the style to make the lines invisible, but attach text or other components to display what you want.
Steve
Thanks Steve! This looks very much like what I looking to do. I appreciate your effort on this, and think this is a very clever solution. I will try to advance this further and post any progress I make.
Thanks again,
Mike
