The program freezes at 62% during a save after copying a feature line to a different site. Has anyone else experienced this ? Is this a known bug ?
The featureline that is giving me problems was created from a closed polyline that was assigned elevations from a surface. This fieatureline represents the top slope of a detention basin and is part of several gradings in the site. I have created a new site that I would like to copy this feature line to for experimentation. After selecting the feature line, then right click, select "Copy to Site...", then select the new site and finally click ok. Everything seems fine at this point. But after trying to save the program freezes. It goes as far as 62%, the task manager shows 100% cpu usage for the program. I then have to end the program through the task manager. After opening the file the featureline is not there since it did not finish saving.
To work around this issue I simply used the AutoCAD "COPY" command to copy the featureline. Then selected the featureline, right click and select "Move to Site...". This seems to work as I can now save the file. Hopefully this may help others that may be experiencing this problem.
EDIT: AutoCAD Civil 3D 2009, Latest SP
I had a similar problem in 2010. I created a feature line from corridor and broke it.
I then tried to move and copy the feature line to the site I wanted. It wouldn't budge.
