Has anyone come up with a solution to the FBK file and resection?
Allan
Has anyone encountered a problem of seemingly extra erroneous/auto generated points?
Example...I take shot #430, which is a code 133(surface/ground/topo). When I import the file into CAD to create my surfaces I find multiple points, almost as if it is shooting the same point 1-4 times. The points all have the exact same data, but the point #s are now 53607182, instead of in consecutive numbered order like normal....Are these erroneous shots generated because I am doing line work at the same time? If so, will it do any serious damage to just delete all of these points? I can't find a setting for continuous/average/repeat shots, that was my first guess to this problem, but some points are defaulted to this weird 500k numbering system without having the original point beneath them.
I have never used Leica products, but am using a TS16 and a 20 controller. Any help would be greatly appreciated.
Rick Jackson
Survey CAD Technician VI
I tried doing that as well, a few times, seems to not be going anywhere....
Also, are you familiar with the structure of Leica raw data? I used to use a topconn, and all of the templates I have were set up with description key sets by the last person here(for the top conn). I need to figure out how to get all of my Leica data to play nicely with the topconn templates. I figured the easiest way to do it was to re-write the description key sets, or create new ones so I have them for both pieces of equipment...Here is a typical point as done with the Leica TS16...
465,507827.456,2190725.149,4781.006, 514, 1.75 21, , , ,
514 is the type of tree(Pine) 1.75 is the diameter in feet and 21 is the diameter in inches. Normally the code assigns the proper symbol and the 1.75 is a scale for the symbol. Then the 21" shows up in the label because of the key set...But I don't really know how to name my points to get it to do the same thing with my Leica data. And the Leica software isn't working on my computer to get into the raw data....it's kind of a mess...
Rick Jackson
