I'm using Autocad for nearly 30years. The company I work for recently stepped "up" to Civil 3D 2014. (My machine is Core i7-3770).
I don't think I've had so many fatal errors in my 30 years of autocad compared to the few months of civil 3d.
When does it happen...........
1.when entering a viewport especially one set up through sheet creation (I've given up on that).
2.when swapping tabs.
3.trying to save named views (doen't work for me when it doesn't crash, save the views but I can only restore the first view created)
4. I get fatal errors when closing civil 3d down after successfully saving/closing my drawing and no other file open, boom!!
Another issue (but I believe its a symptom of the problem) is not being able to see the content of viewports or only seeing partial content. prints ok but I can't see it on screen (maxactvp=64) only 3 vps. I need to swith tabs and switch back to see it and even then I'm not sure if everything is there.
If I need to rotate the view, forget it, the content shows up in the other viewport (distorted) and try as I might the intended viewport is blank.
I've tried the whipthread, LAYOUTREGENCTL in various arrangements but makes no difference.
Anyone experience similar issues? Any solutions or suggestions would be appreciated. (AC settings?, PC settings?)
My plain autocad setup works fine on the most part, a fatal error here and there but I can live with it.
I could go on complaining but it's Friday so I'll leave it there.
Regards
Sean
I don't have any of those problems. I've been running 2014 for nearly a year. The first thing I'd suggest is updating your video drivers. If that doesn't work I'd try repair then reinstall.
What video card do you have?
Allen Jessup
Civil 3D 2012 SP 3 / IDSP 2014
Dell Precision T3610, Xeon CPU 3.70 GHz
Win 7 Pro, 64-bit,32 GB RAM, Nvidia Quadro K4000
Samsung SSD 512GB
HGST (WD) 512GB drive
Allen Jessup
CAD Manager - Designer
Hello Allen,
Thank you for replying. I've copied my 3dconfig log below. Maybe you can take a look and comment on settings?
thanks
Sean
Performance Tuner Results Log
Version:
Date of Last Tune:
Machine Configuration
Processor Speed : 3.4 GHz
RAM : 16339 MB
3D Device
Name : NVIDIA Quadro K2000
Manufacturer : NVIDIA
Chip set : Quadro K2000
Memory : 1715 MB
Driver : 9.18.0013.1090
Your machine contains a 3D Device that is not certified.
As more graphics cards and 3D display drivers are tested, they are added to a list on the Autodesk website.
You can check for updates and download the latest certification list at any time. Run the 3DCONFIG command and click the Check for Updates button.
Current application driver: acaddm11.hdi
Current Effect Status:
Enhanced 3D Performance: Available and on
Smooth display: Available and off
Gooch shader: Available and using hardware
Per-pixel lighting: Available and on
Full-shadow display: Available and on
Texture compression: Available and off
Advanced material effects: Available and on
Available application drivers and effect support:
Software driver
Effect support:
Enhanced 3D Performance: Not applicable
Smooth display: Not applicable
Gooch shader: Software emulation only
Per-pixel lighting: Not applicable
Full-shadow display: Not applicable
Texture compression: Not applicable
Advanced material effects: Not applicable
Autodesk driver: Not Certified
Effect support:
I don't see any problems with the settings. I do see that there are new drivers available. My suggestion that updating the drivers should be the first step still stands.
Allen
Allen Jessup
Are these Legacy drawings or brand new creations?
I have definately seen this behavior in the former. Re-creating tabs and deleting the old appears to work for me.
Your Name
Your Name
Hi Allen,
I see that the card is not certified but when I check for updates it responds with up to date.
I understand that it being not certified shouldn't cause a problem, what is your view?
thanks
Sean
Hi Joe,
My work in civil 3d over the past few months has consisted mainly of new work on blank templates. Although the common denominator would be my template drawing that I use to setup my sheets. As far as I can see dwt file is OK. I'll setup a set using another template and see what happens.
I'll try anything at this stage. You mentioned deleting the old tab in your drawings, what do you think could be wrong with the old tab that can't be fixed?
Regards
Sean
The card should be fine. Your drivers are 9.18.0013. The latest from the nvidia site are:
I'm not saying this will solve the problem. But it's the first thing I'd try.
Allen
Allen Jessup
Your Name
Your Name
