When trying to open a 3D modeling .dwg file I get this message: "Fatal Error:Unhandled Violation Reading Oxe91b3dec Exception at 5ed81f4eh." Any solutions to the problem. Recover drawing does not help. Thanks.
I'm not sure what it means to send the file to check. Part of the original question is that the file will not even open all the way, it kicks me out before being completely downloaded then gives the fatal error message.
i still can't get this this file to work without getting the error message. Can you please try checking the file that is attached. Thanks.
Scott Ramsey
It opened up on my C3D 2015 (& C3D 2014) instantly without a hitch.
Bill
Hi Scott,
the file also opened up on my computer in Civil 3D 2014 without issues.
I have run a PURGE and AUDIT and sved it again. In order to make sure there are no file related issues, please try opening the attached file on your computer. If that does not work I suggest to 1. reset the Civil 3D user profiles and/or 2. conduct a clean uninstall/reinstall of the software.
Hope this works,
Karsten.
