alloftin
Message 1 of 1 (133 Views)
Fatal Error While Selecting an Imported Shape File
133 Views, 0 Replies
06-18-2012 12:30 PM
Just received a shapefile from our GIS department.  I imported the file in with no problem.  But then when I went to select the object I received the attached fatal error message.  I thought maybe restarting the computer would help, as it has with multiple issues I have had, but it didn't help. I didn't want to leave the unstable image in the file just in case someone else was working and accidentally selected the objects.  I found a way around the issue but it took a little longer than I wanted it to, and as they say time is money. However, I didn't figure out why the program kept crashing, and it still does if I select the objects.  I have never had this problem with any other shapefiles.  Any help would be greatly appreciated.
AutoCAD C3D 2010
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
