I'm trying to extrude a series of 3D faces, a very large series, over 200,000 3D faces. I´ve done this before only it was not on so many faces as I can select only like 3,000 faces aprox at any one time or the computer crashes.
I think this problem could be solved, or at least I could save some time, if the extruding preview could be turned off. By extruding preview I mean that when I enter the extrude command and select the objects to extrude, then immediatly there's a preview of what the objects would look like once they're extruded and that's what's causing the delay and the crashes.
Is there any way this could be turned off?
I've attached an image in case I didn't explain myself.
Thank you and I'm sorry if this post is not in the right place.
Mark Green
Working on Civil 3D in Canada
Try the attached lisp routine. This will make a selection set of your 3dFaces, ask for an extrusion height and will go through and individually extrude the faces. It can take a long time, so be patient.
I changed the .lsp file to .txt so that I could post here. You will need to change the file extension back to .lsp to make it loadable in AutoCAD.
Tim
