Civil 3D Forum
Extracting polylines from a corridor
2 REPLIES 2
Umit.Arslan
864 Views, 2 Replies
Hi
        When i want to extract polyline from corridor, unexpectedly the program does now give me the chance to choose the right point code.i want to have a polyline from "P1" but it selects "P2" which are on the same vertical line.I am wondering if there is an option to select the point code manually from a list.
        I have found a vba (attached) to run it on my civil 3d 2014 but i couldnt.
- Umit Arslan -
Survey Engineer
Civil 3D 2018 x64
Windows 8.1 Pro 64-bit
32GB RAM
2 REPLIES 2
jmayo-EE
in reply to: Umit.Arslan
Can you select the correct one if you go to the corridor properties dialog, feature lines tab and turn off (set style to None or a Hidden Style) the unwanted code?
John Mayo
Umit.Arslan
in reply to: jmayo-EE
Yes
- Umit Arslan -
Survey Engineer
Civil 3D 2018 x64
32GB RAM
Rail Community
