Civil 3D Forum
Extracting a contour for a specific elevation
2 REPLIES 2
autoMick
3791 Views, 2 Replies
Hi, I have a surface from which I need to extract the outline for set of a specific elevations (e.g. 1.44 m as well as quite a fews others at irregular intervals). I'm familiar with extracting objects such as contours from surfaces, but I'm stuck on how to efficiently create a single contour at a given elevation.
Any suggestions?
- Mick
Civil3d user in Australia since 2012.
2 REPLIES 2
Jeff_M
in reply to: autoMick
User Defined Contours....
Be sure the Surface STyle is set to display User Defined Contours.
autoMick
in reply to: Jeff_M
Well I'm learning every day !
I had briefly looked at that but missed the display user contours bit as you noted at the bottom of your post - I never actually noticed that this was separate from the other contour categories.
Thanks Jeff ! Perfect solution
- Mick
Rail Community
