How can I extract volumes from a surface between two specific elevations? So if my range of elevations varies from 400' to 2500', how can i extract the volume from 1000' up to 2500' without any of the other volumetric data from the surface areas bleow the 1000'? Is that even possible without creating a profile? I am using Civil 3d 2014. Any help will be greatly appreciated!
-Ryan
Solved by Joe-Bouza. Go to Solution.
You cant get a volume from a single surface you must compare one surface to another
Joe Bouza
