neilyj
Message 1 of 8 (507 Views)
Extract linework from corridor
507 Views, 7 Replies
01-14-2013 01:07 PM
What's the best workflow to extract the linework from a corridor - I need the linework as 3D polys for export to another modelling system??
I have tried the extract feature line from corridor but it is incredibly tedious so I have lately done the following
1 Rebuild Corridors and Save file
2 Select Corridor, Isolate and Explode twice
3 Select all the lines and JOIN which then creates 3D polylines
4 Wblock the 3D polylines
5. DO NOT RESAVE...!!!
Is there a better way?
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
Jeff_M
Message 2 of 8 (504 Views)
Re: Extract linework from corridor
01-14-2013 01:15 PM in reply to: neilyj
Yes, but you've already said you can't utilize it :smileysad: Better way
neilyj
Message 3 of 8 (494 Views)
01-14-2013 01:46 PM in reply to: neilyj
I'd love to know why a routine like this Sincpac one isn't available ootb in civil 3d and why Autodesk have made extracting featurelines from the corridor so longwinded.
looks like I'm sticking with the explode method for the time being
neilyj
sboon
Message 4 of 8 (478 Views)
01-14-2013 04:18 PM in reply to: neilyj
Export the corridor drawing to ACad.  The exported drawing will have 3d lines in it.  Assuming that you can isolate them using layer control or some other method then it's simple to join them into 3d polylines and erase everything else.
neilyj
Message 5 of 8 (462 Views)
01-15-2013 12:42 AM in reply to: sboon
This is essentially the same as my exploding method but arguably less prone to disaster as the original data is preserved in the event of "a senior moment" and saving the exploded corridor...:smileyhappy:!!!!
EDIT: Just tried this and the Z coordinate is 0 (when OSNAPZ is either 1 or 0) but it is preserved using the Explode method.
neilyj
neilyj
Message 6 of 8 (451 Views)
01-15-2013 04:50 AM in reply to: neilyj
Using the _AeccCreatePolylineFromCorridor command it is easy to extract 3D polylines (presumably this is what the Sincpac routine uses?) but as they are all placed on the current Layer it is quite tricky to know what each polyline represents unless the current Layer is changed for each polyline
neilyj
mathewk
Message 7 of 8 (428 Views)
01-15-2013 07:27 AM in reply to: neilyj
Change to a 3D view before exporting the drawing. You should get 3D elevations.
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
sboon
Message 8 of 8 (417 Views)
01-15-2013 08:10 AM in reply to: mathewk
I commented on this issue last week in this thread.
If your export has to be exclusively 3d polylines then you'll want to check after running the join command.  Any of the exported lines that are a single isolated segment will not be joined, and will not convert to polylines.  I find this happens often with short ditch segments where the daylight is flipping between cut and fill.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
