AutoCAD Civil 3D General
*Expert Elite*
Murph
Message 11 of 16 (704 Views)
Re: Extract and export surface contours and labels
05-06-2011 05:40 AM in reply to: Joe-Bouza
Refine your explode command and add this
defun Bang (str)
  (vl-load-com)
  (setq sapi (vlax-create-object "Sapi.SpVoice"))
  (vlax-invoke sapi "Speak" str 0)
  (vlax-release-object sapi)
(Bang  "BANG ")
Murph
Supportting the troops daily.
Member
pyrmom
Message 12 of 16 (296 Views)
09-04-2013 07:14 AM in reply to: CARLBOYER8135
I tried extracting the contours, but it does not accomplish what I need. I use Civil 3D 2013 and I sent my drawing (with surface contours) to someone using Carlson 2013. My contours were not visible. When I extracted them and sent it they could not open the drawing at all. I had to completely explode the surface and then I lost my labels. Even though the resultant polylines maintained their elevation, I was unable to label the polys with elevations.
*Expert Elite*
jmayo
Message 13 of 16 (294 Views)
09-04-2013 07:49 AM in reply to: pyrmom
Did you try using the Export To AutoCAD commands? This may be the best way to send the surface.
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
Member
pyrmom
Message 14 of 16 (285 Views)
09-04-2013 12:03 PM in reply to: jmayo
I think maybe exporting the surface to an XML file might be the way to go. I tested it with Microstation, and it was successful.
Member
pyrmom
Message 15 of 16 (284 Views)
09-04-2013 12:06 PM in reply to: pyrmom
I did not know I could do that. I am going to test it. Thanks!
Member
pyrmom
Message 16 of 16 (281 Views)
09-04-2013 12:09 PM in reply to: pyrmom
It worked! Thanks so much. I didn't lose the contour elevation labels either.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
