Active Member
mheimburger
Message 1 of 3 (285 Views)
Extract Survey Data from Vault
285 Views, 2 Replies
09-17-2010 10:23 AM
When we changed from LDD to C3D we installed Vault and completed several survey projects.  Now we are moving away from Vault and would like to move the survey data.  I go through the process of converting from Vault to Data Shortcuts but the survey data is not available.  Files Survey.sdb & Survey.sdx are tranferred but when I direct the working folder to their location no survey database shows up.  Is there a way to utilize the survey data without using Vault?
Product Support
AlmasSuljevic
Message 2 of 3 (274 Views)
Re: Extract Survey Data from Vault
09-17-2010 01:42 PM in reply to: mheimburger
What you can do is go to Vault Explorer and check out Survey.SDB file. This will make a copy of the survey database in your Working Folder directory. Then see if you can obtain your survey database.
Check this link for reference: http://beingcivil.typepad.com/my_weblog/2010/05/from-vault-to-data-shortcuts-move-survey-database.ht...
Let me know if it helps.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Please click on "Accept as Solution" if post helped you resolve the issue.
Active Member
mheimburger
Message 3 of 3 (248 Views)
09-21-2010 10:34 AM in reply to: AlmasSuljevic
Thanks Almas, you had sent me that link previously and I lost it.  It works great.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
