AutoCAD Civil 3D General
*Expert Elite*
neilyj
Message 1 of 11 (228 Views)
Extent of rockfall netting
228 Views, 10 Replies
11-13-2012 12:08 PM
I have a model of a platform at 29.00m cut into rock and need to find  areas where the rock cut is 2m or more as this will require netting - any ideas of a quick way to do this??
 Extract the 31m contour and see where it runs is the best I've come up with......
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2014 (mainly Civil 3D 2014 UKIE SP1 & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
*Expert Elite*
Neilw
Message 2 of 11 (225 Views)
Re: Extent of rockfall netting
11-13-2012 12:36 PM in reply to: neilyj
Would not a CUT/FILL depth analysis work?
Neil Wilson (a.k.a. neilw)
Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
WIN 7 64 PRO
HP Pavillion h8xt, i7 2600, 12 GB
RADEON 6450, 1 GB
http://www.sec-landmgt.com
*Expert Elite*
neilyj
Message 3 of 11 (220 Views)
11-13-2012 12:45 PM in reply to: Neilw
The excavation surface vs a 31m plane surface??
neilyj
*Expert Elite*
Neilw
Message 4 of 11 (217 Views)
11-13-2012 12:48 PM in reply to: neilyj
I don't understand your scenario. I assumed you have a proposed surface and want to determine where the cuts are >2m vs. the existing. What do you have to work with?
WIN 7 64 PRO
RADEON 6450, 1 GB
*Expert Elite*
neilyj
Message 5 of 11 (213 Views)
11-13-2012 01:04 PM in reply to: Neilw
Yes I have a proposed surface and I'm only really interested in the portion that is below rockhead and is higher than 2m above the platform level
neilyj
*Expert Elite*
Neilw
Message 6 of 11 (206 Views)
11-13-2012 01:30 PM in reply to: neilyj
In the ranges for the depth analysis, only include those values that fall within the desired parameters.
WIN 7 64 PRO
RADEON 6450, 1 GB
*Expert Elite*
BrianHailey
Message 7 of 11 (189 Views)
11-13-2012 03:50 PM in reply to: neilyj
No. Create a volume surface of your platform and your rock surface. Run an elevation analysis on the volume surface. Anywhere the elevation of the volume surface is greater than 2m is where you will need the protection. You can then stylize the volume surface and to display those areas automatically if the design changes.
*Expert Elite*
Neilw
Message 8 of 11 (185 Views)
11-13-2012 04:11 PM in reply to: Neilw
I assumed you knew how to create a cut/fill analysis. My apology for not being more explicit.
WIN 7 64 PRO
RADEON 6450, 1 GB
*Expert Elite*
neilyj
Message 9 of 11 (165 Views)
11-14-2012 12:25 AM in reply to: BrianHailey
Thanks Brian I'll try that ....
This will identify the locations where the rock netting is required but the next task is to compute the area of the rock face to be netted.
Perhaps draw a boundary around the affected areas, apply as outer boundary and review the 3D area surface properties??
neilyj
Valued Contributor
Message 10 of 11 (149 Views)
11-14-2012 05:59 AM in reply to: neilyj
I just checked and I believe in the Legend table for volumes you can add 3d area or 2d area.  We use it all the time in the slopes legends to calculate sq footage of walls.
Hope that helps,
Conan Witzel
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
