HI all, I have had this trouble for a while now, thought I might finally ask if anyone eles is having the same issue, or knows a solution.
I have a background aerial image (jpeg) attached to a drawing for reference. When using extend as part of the trim command, to extend a line to another line, extend will not work. even when I unload the image. I have to detach the image for this to work, which is a PITA as I use extend a lot.
Can anyone help?
Cheers
Leigh
Solved by Jeff_M. Go to Solution.
