Civil 3D Forum
Expressions
2 REPLIES 2
StumpMasterFlex
453 Views, 2 Replies
Expressions
When I open the expression variables available in a label style, I see different options available for different label styles.
 Can I combine expression variables from different label types?  For example, say I want to make an expression that takes the Surface Elevation from a spot elevation label and subtract a variable from a pipe variable such as end invert elevation?
If you can do this, were can I find the expressions file on my computer or network?  Can they just be dragged and dropped between label styles?
Kindest Regards
Michael,
Civil Design Technologist (Exploration Technologist)
Civil 3D 2013
Windows 8
Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
32. GB
64-bit Oepration System, x64-based processor
No Pen or Touch Input
2 REPLIES 2
Jay_B
in reply to: StumpMasterFlex
The Help is a good place to start to become familiar with Expressions and yes there are different options for various style types and some have none available. You're pretty much limited to the parameters available for a given style type. But as an example a parameter within a Structure Style Expression is Surface Elevation at Insertion Point.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
StumpMasterFlex
in reply to: Jay_B
Thank you very much. I kind of figured we were limited. We will work with
what is available.
Kindest Regards
Michael Stempfer
Kindest Regards
Michael,
Civil 3D 2013
Windows 8
32. GB
Rail Community
