Civil 3D Forum
Expression of grades on Profile View bands...or anywhere for that matter...
4 REPLIES 4
peterthomson9209
800 Views, 4 Replies
Hi All,
Typically here in NZ, and for as long as I have been in this business, we have expressed slopes in the form ...2 : 1  but the same grade would be expressed as   1 in 2.
I wonder how much support there would be from well qualified Civil Engineering folk to get AutoDESK to allow this form of display for grades?
cheers,
Peter T
cheers,
Peter T
Dunedin, New Zealand.
C3D 2011, Win 7, Dell M6500, 8Gb RAM
4 REPLIES 4
CivilFF
in reply to: peterthomson9209
1. You look at the same grade and you can describe it as run:rise or rise:run format:
1. format illustration
2. You can choose that the first one will be “rise” and this grade format is called rise:run.
2. first rise
3. You can also choose that the first one will be “run” and this grade format is called run:rise.
 This one is preferred by You:
3. first run
CivilFF
www.civilfastforward.com
peterthomson9209
in reply to: CivilFF
Thank you...but...
My point was that we would like to express our grades as ...  1 IN 200    not   1 : 200.
C3D does not give us that opportunity.
cheers,
Peter
cheers,
Peter T
Rise over run - run over rise has always been the unitized value and that is what c3d does. 1 in 200 would physically mean 100 in 20,000 which is about 0.005%? Are you sure about that? Seems might flat.
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People)
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win10 OS
CivilFF
If you want to build the expression format like e.g. 1 IN 2 do the following steps:
1. Build your own expression and call it e.g myRun
1. expression myRun
1/ABS({Grade between Point 1 and Point 2})
2. Build your own grade label and use the myRun expression
- add the constant description 1 IN and add the myRun expression
- change the myRun Precision into 1
2. label myRun
1IN<[myRun(P0|RN|AP|GC|UN|Sn|OF)]>
3. You will get your preferred description format
3. final myRun
If you want to show the minus sign in this format e.g.   -1IN2 :
4. Add a new expression and call it e.g. mySign
4. expression mySign
{Grade between Point 1 and Point 2}/ABS({Grade between Point 1 and Point 2})
5. Use this expression mySign in your label
5. label mySign
<[mySign(P0|RN|AP|GC|UN|Sn|OF)]>IN<[myRun(P0|RN|AP|GC|UN|Sn|OF)]>
6. Now you can also show the sign of your grade
6. final mySign
I hope it will help
CivilFF
Rail Community
