1. Only AutoCAD objects can be exported to shp format, no civil 3D objects.
2. Path to the location you are exporting to needs to a short path, anything
in a folder, in a folder, in a folder and in another folder will cause
issue.
3. File name of the file you are exporting to needs be dos compliance, no
special symbols or weird fonts
4. Assuming you have all the SP install and hot fixes, try the old standby
command "Mapexport4"
Murph
http://map3d.wordpress.com/
"10acken" wrote in message news:6378639@discussion.autodesk.com...
We're using Civil 3D 2009. I have recently been trying to export to a shp
file using the Map=>Export function. Every time I do, CAD crashes and gives
me this error message:
FATAL ERROR: Unhandled c000000dh Exception at 78138aa0h
At first I though maybe I had a bad install, but I can re-create the problem
on multiple machines. Has anybody ever run across this problem? It happens
every time, without exception, regardless of the type or number of objects I’m
trying to export.
