Murph,
I recently installed a new hard drive and now have the same issue mmcmanus originally posted.
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Exporting-SHP-files/m-p/2637024#M125748
Unfortunately, when I follow both of your links I get the 404. Could you please help me out?
Murph,
I am still not able to click on the two links you posted as a response to mmcmanus's original post. However, I did a search over on the Map 3D group and found a solution from another post you had replied to. I modified the mapexport.ini file as you suggested there and I am back in business.
Thank you
