Civil 3D Forum
Exporting Multiple Point Groups
11 REPLIES 11
Message 1 of 12
910 Views, 11 Replies
Hi, I have about 50 point groups that the client needs in an ENZ format, is it possible to export them all at once with the name of the point group being the name of the file?
if so, the more annoying part of this is that I actually have to make the ENZ file an ENZD file with the D being the name of the file for each point, if both of these things are possible and you can explain it to me in a way I understand you are guaranteed to go to heaven lol
11 REPLIES 11
Message 2 of 12
_Hathaway
Whenever I have to export multiple point groups I make a new point group and then add the other point groups to it. It's not too painful. Not sure how you're going to handle your 'D' component though.
Message 3 of 12
in reply to: _Hathaway
the client needs them separated by the name of each file so i'm not sure if that's still possible if i combining them all into one point group?
Message 4 of 12
_Hathaway
You need to change the 'D' component of each group prior to combining them using whatever method is most efficient for your needs.
Message 5 of 12
is there a way to make the D component to be the name of the file?
Message 6 of 12
correction - the name of the POINT GROUP, not file
Message 7 of 12
_Hathaway
Use the Override function within each point group. Granted you would have to do it manually but it wouldn't take too long.
Message 8 of 12
please can you give me a little more instruction on that?  it would help alot ... on which tab?
Message 9 of 12
_Hathaway
R click on a point group name, select properties, then go to the Override tab, check the raw description box and then enter the point group name, apply. close.  Rinse and repeat for each group.
Message 10 of 12
THANKS!  .... now another hurdle. I want to export as ENZD and that format is not available so I tried creating it and it saved it but it is not available when I go to export points, did I miss something?  just a little instruction on how to make a ENZD format so that it is selectable when i go to export points and you won't hear from me no mo (at least for today lol)
Message 11 of 12
UGH, it never ends, I did what you said and tried exporting as PENZD for now and there is nothing in the D column?!
Message 12 of 12
troma
Don't forget that Excel (& probably OO Calc) can open .csv files.
This could be your easiest way to add the D column, delete the P, combine all of the point groups together and any other editing.
Mark Green
Working on Civil 3D in Canada
Rail Community
