Hi, I have about 50 point groups that the client needs in an ENZ format, is it possible to export them all at once with the name of the point group being the name of the file?
if so, the more annoying part of this is that I actually have to make the ENZ file an ENZD file with the D being the name of the file for each point, if both of these things are possible and you can explain it to me in a way I understand you are guaranteed to go to heaven lol
the client needs them separated by the name of each file so i'm not sure if that's still possible if i combining them all into one point group?
R click on a point group name, select properties, then go to the Override tab, check the raw description box and then enter the point group name, apply. close. Rinse and repeat for each group.
THANKS! .... now another hurdle. I want to export as ENZD and that format is not available so I tried creating it and it saved it but it is not available when I go to export points, did I miss something? just a little instruction on how to make a ENZD format so that it is selectable when i go to export points and you won't hear from me no mo (at least for today lol)
Mark Green
Working on Civil 3D in Canada
