Hmmm... That might make it challenging to use. Not being a Microstation user, I would have no idea what to do in order to create a proper translation library.
Is that the sort of thing that would ideally be provided by the DOT (or whoever wants the Microstation submittals)?
Also, what happens to civil objects? Does "Export to DGN" work like "Export to AutoCAD", and destroy all Civil elements? If so, I presume that a LandXML dump would also be required.
How about on the Microstation end? If it can open C3D drawings, can PowerCivil or InRoads convert all the Alignment, Profile, Surface, etc. data?
Our experience so far has primarily been on the other end, where we use C3D to work with drawings created in Microstation (usually InRoads), using the "Import DGN" option to get the data into C3D. We can generally work with the files, but it is far from seamless, and we run into a lot of "quirks". But since we are typically using the DGN files for construction, we can typically do what we need to do. We don't have to worry about submitting things to a review agency. Civil elements typically do not come through, and TIN surfaces in drawings in particular are usually mangled beyond all use, but we usually get enough linework that we can get by.
We've even submitted asbuilt drawings back to the engineer (typically when working with the Army Corps), but so far, we've just given them DWG files. From what I gather, they then take that data and merge it into their DGN files somehow. Again, they seem to suffer some "quirks" and annoyances, but they seem to manage to get what they need.
-- Sinc
http://www.ejsurveying.com
http://www.quuxsoft.com
Sinc
