Civil 3D Forum
Exporting Civil 3D Points to Shapefile with "Z" Elevation
24 REPLIES 24
Message 1 of 25
rick_JWMA
3466 Views, 24 Replies
Using Civil 3D 2013. I've exported my Civil 3D points to an SDF and then to a shapefile. I cant get the "Z" elevation to come with it. Northing and Easting is correct, only problem is that is holds a zero elevation. Any assistance or suggestions on how I can get the elevations to show correctl in the shapefile?
24 REPLIES 24
Message 2 of 25
ToddRogers-WPM
in reply to: rick_JWMA
When you do MAPEXPORT and export to an ESRI Shapefile (.shp).  Once you have selected your points, click on the Data tab.
Then select the Select Attributes button.
Expand Properties, expand and check the box for X1, then Y1, and Z1 (not the X1,Y1,Z1).  Select them individually.
You should be good to go.
Todd Rogers
BIM Manager
Blog | Twitter | LinkedIn
Message 3 of 25
rick_JWMA
in reply to: ToddRogers-WPM
Once I MAPIMPORT the SDF File into a new drawing, the SDF Geometry Position Z is 0.00. The attrubute information attached provides the correct Z elevation (OD:Points). Do SDF/SHP Point Files contain elevation in attribute form only and no elevation on the physical point in the drawing? Thanks for your assistance. Greatly Appriciated.
Message 4 of 25
ToddRogers-WPM
Do have attributes that you are trying to convert into Civil 3D points?
Todd Rogers
BIM Manager
Message 5 of 25
rick_JWMA
No I am not trying to use attributes to create Civil 3d Points. I already have Civil 3D points in a drawing (PENZD). Points created from a .txt file.
Message 6 of 25
rick_JWMA
Ultimate goal is to get from Civil 3D Point to a Shp file to send of to a client with Z elevations on the points (if possible).
Message 7 of 25
ToddRogers-WPM
If they are attributes, use the command EATTEXT to convert them into a .csv file, then you can import that into the drawing.  If you want me to do it for you, attach the drawing here.
Todd Rogers
BIM Manager
Message 8 of 25
ToddRogers-WPM
Gotcha.  Attach the .txt file and I will do for you.
Todd Rogers
BIM Manager
Message 9 of 25
antoniovinci
Please share with us the shapefile with Z attribute, thx.
Message 10 of 25
rick_JWMA
Attached is the .txt File.
Would it be possible to let us know the steps it took you to get to final product?
Rick
Message 11 of 25
ToddRogers-WPM
What coordinate system do you want this in?
Todd Rogers
BIM Manager
Message 12 of 25
rick_JWMA
UTM with NAD 83 Datum, Zone 10, US Foot, Central Meridian 123d W
Message 13 of 25
ToddRogers-WPM
See if this is what you want...if so, I will give you instructions.
Todd Rogers
BIM Manager
Message 14 of 25
rick_JWMA
Yes!,
Exactly what I am looking for.
Message 15 of 25
ToddRogers-WPM
Ok.  You were doing the correct procedure at first.
1.  Import points into C3D
2.  Output tab of the ribbon, Export Civil Objects to SDF
3.  Set your projection
4.  MAPIMPORT, select SDF file you just created
5.  Uncheck everything except for Points.  In the Data column click in the cell, then click the ellipsis...
6.  Once in there, toggle the radio button for Create Object Data, the select the button for Select Fields...
7.  Make sure they are all checked, then click OK.
8.  Now you can MAPEXPORT out to a SHP file.
Good luck!!
Todd Rogers
BIM Manager
Message 16 of 25
TerryDotson
If you want to avoid jumping through hoops, MapWorks Points contains Point Shapefile Read/Write tools that (in the case of export) creates a shapefile directly from the AECC_POINTS in a quick single step.
Message 17 of 25
Another good program is Global Mapper.
Sent from my Verizon Wireless 4G LTE Smartphone
Todd Rogers
BIM Manager
Message 18 of 25
It is very good, but it doesn't read AECC_POINTS inside Civil3D.
Message 19 of 25
Murph_Map
The quickest and easy way I would do it is save the civil3D dwg as an AutoCAD dwg file format. (ExporttoAutoCAD)
Then in that dwg use map export to export to ESRI shp format. When you export open the "Options" tab, click on "Drivers" and check the radio button for 3D.
Simple and no 3rd party or other formats needed other than the dumb down AutoCAD dwg format.
Murph
Supporting the troops daily.
Message 20 of 25
TerryDotson
in reply to: Murph_Map
Simple and no 3rd party ...
Also your procedure gives you no point numbers, no descriptions, etc.
Rail Community
