We are using Carlson Connect to import all of our CRD files into C3D 07. A new job was created with at least 2000 points and we need to export these as a crd file. When we use carlson connect to export, it only exports the 146 points that were created manually. Is there a setting that needs to be changed or is not possible to export these points using Carlson Connect. I know I can create a csv and go that route, but carlson connect would save a bit of time. All known updates have been installed. Thanks for the help.
