Civil 3D Forum
Export to AutoCAD missing stuff
4 REPLIES 4
TherealJD
1668 Views, 4 Replies
i've audited and purged the drawing prior to doing export, but i keep getting stuff missing on the exported file...
See before / after attachment. Any suggestions on what I could do, muchly appreciated.
Using Civil 3D 2009 -->export to AutoCAD 2007
4 REPLIES 4
jefflambert9091
in reply to: TherealJD
I had a problem with a drawing that would go through all the motions but not save the file. I found I had to recover the drawing, purge Unnamed Objects and then I Purged All. It may be a shot in the dark, but FYI.
Jeff
Civil 3D 2024
TherealJD
Tried a recovery on the drawing.. and purged everything in the drawing. Still having the same issue...
Tried auditing the drawing as well.. still missing the same stuff when exporting.
Go back to 2010 and use AecObjExplode, and then saveas 2007.
Matthew Anderson, PE
TherealJD
this worked.. thanks! 🙂
Rail Community
