AutoCAD Civil 3D General Discussion
Distinguished Contributor
Cadbeyond
Message 1 of 33 (538 Views)
Export the Geotechnical modules object to AutoCAD
538 Views, 32 Replies
08-19-2013 07:07 PM
It seems that the object was created by the Geotechnical modules.  It cannot be exported to AutoCAD. I tried to use the command "Export or Explode", all object will be disappeared e.g. borehole onto the profile, geologies contour line onto the profile… after clicked the commands.
Anyone knows how to do or any trick can help? Thanks.
*Expert Elite*
neilyj
Message 2 of 33 (517 Views)
Re: Export the Geotechnical modules object to AutoCAD
08-19-2013 10:41 PM in reply to: Cadbeyond
I have sussessfully used Export To Autocad to export boreholes and borehole strips but have never tried with profiles although I don't imagine there would be any issues
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
Cadbeyond
Message 3 of 33 (502 Views)
08-20-2013 12:02 AM in reply to: neilyj
Yes. The command "export" or "explode" is no use for the borehole strip onto the profiles.
*Expert Elite*
neilyj
Message 4 of 33 (500 Views)
08-20-2013 12:08 AM in reply to: Cadbeyond
I'll try and dig out one I've produced and see what happens when I export
neilyj
Cadbeyond
Message 5 of 33 (458 Views)
08-20-2013 11:01 PM in reply to: neilyj
Did you get the result? :smileyhappy:
*Expert Elite*
neilyj
Message 6 of 33 (451 Views)
08-20-2013 11:57 PM in reply to: Cadbeyond
It was down my priority list but I've just done it and and the projected profiles do disappear when Exported to AutoCAD. The boreholes and strips remain as expected.....feels like a support ticket about to be raised
neilyj
Cadbeyond
Message 7 of 33 (437 Views)
08-21-2013 08:13 PM in reply to: neilyj
And it is not possible to project the borehole id onto the profile view directly! I finding the another ways! :smileyfrustrated:
*Expert Elite*
neilyj
Message 8 of 33 (429 Views)
08-21-2013 11:48 PM in reply to: Cadbeyond
Yes - this is a fundamental requirement...!!!!
Not sure if it can be done via Projected Objects in the normal way
neilyj
Cadbeyond
Message 9 of 33 (423 Views)
08-22-2013 12:24 AM in reply to: neilyj
It needs the tool (e.g. KeyAGS) to convert the AGS to meaningful spreadsheet and create a point group and finally project to profile view in Civil 3D!
*Expert Elite*
neilyj
Message 10 of 33 (420 Views)
08-22-2013 12:34 AM in reply to: Cadbeyond
You can CTRL+A, then CTRL+C in Borehole Manager and then CTRL+V into Excel to get the data into a format that can be manipulated into a usable point file format and used in Civil 3D.
You could even set up a point file format in Civil, based on the Borehole manager output, to read a csv directly without rearrranging the columns etc in Excel.
The CTRL+ to Excel trick works for the Strata manager as well
neilyj
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
