Civil 3D Forum
Export polyline to shp file from C3D 2010
5 REPLIES 5
2673 Views, 5 Replies
I am able to export to SDF but I get nothing when trying to go the two shp formats available. was a "parcel", but i exploded to lwpolyline.
Do i need a patch to make this work???
I am a C3D newbie and am struggling wit h user interface, but know that mapexport command line looks like it is supposed to work.
thanks
tim
5 REPLIES 5
First, do you have all the service packs installed?
Second are you checking the polygon or line type object in the export dialog
in the object type of the selection tab?
Murph
http://map3d.wordpress.com/
wrote in message
news:6317533@discussion.autodesk.com...
thanks
tim
andrew.malizia
I have been unable to successfully export to SHP in Civil 3D 2010 also. The portion of the dialog box for object type (point, line, polygon) is gone from the top. Is there a fix for this? I am up to date with the service packs. Thanks.
Andrew
EDIT: Solution found on Murph's Blog... http://map3d.wordpress.com/2008/11/01/exporting-to-shp-with-civil-3d-and-errors/ worked like a charm. Thanks! Edited by: andrew.malizia on Jan 15, 2010 6:02 PM
The official fix.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13251791&linkID=9240697
Murph
"andrew.malizia" wrote in message news:6319178@discussion.autodesk.com...
packs. Thanks.
Andrew
I can't export sipmle polygon in shapefile drown with closed polyline. In data tab I've selceted AcDbCurve->2DPolylines atributes. Only thing I get is No entity to export eror.
antoniovinci
Check this for all your polygons to be exported, sir.
Rail Community
