Civil 3D Forum
Export map as dwg
6 REPLIES 6
1535 Views, 6 Replies
Export map as dwg
I have a map file with tif images (and .tfw files for coordinate info). I
want to be able to export this file to a dwg. When I click "current map as
dwg" images are not in the new file.
How can I export the map file with images to a dwg file?
Thanks-
John
C3D 2010
3G RAM
XP PRO, SP2
6 REPLIES 6
Did you use mapiinsert or data connect to bring in the image file? If you
used the mapiinsert then it's still the same image in the same location. If
you used the data connect then the image is converted into a png file and in
the users document folder(Default) with a name of GisGrid.pgn and place on a
drawing layer named GisGrid. Open up the xref manger and look for the image
in the new dwg. Also when you used the data connect and save the map to a
dwg it should ask if you want to detach and erase the image (which I see has
no effect on the dwg).
Murph
http://map3d.wordpress.com/
"John" wrote in message
news:6389136@discussion.autodesk.com...
Thanks-
John
C3D 2010
3G RAM
XP PRO, SP2
John hi,
AutoCAD files (DWG) can incorporate raster images as OLE objects but this in
not recomended.
The images should stay out of the DWG files as attachments.
Arad
Thanks-
John
C3D 2010
3G RAM
XP PRO, SP2
I am using Data Connect. I went to connect to data> add raster image..>
source file or folder (I picked the tif)> connect> add to map. Then it adds
the images as layers.
I tried to the "current map as dwg". Before I read your post I was saving
the file on a server.
After reading your post I saved exported my file to my desktop and it
worked.
Should this make a difference? I think I will just move the dwg and image
files to the server and remap the images to relative.
-thanks
John
"Murph" wrote in message
news:6389187@discussion.autodesk.com...
Murph
Thanks-
John
C3D 2010
3G RAM
XP PRO, SP2
I do want to reference them as you said, thanks-
"Arad Gazit" wrote in message
news:6389188@discussion.autodesk.com...
John hi,
not recomended.
Arad
Thanks-
John
C3D 2010
3G RAM
XP PRO, SP2
Ok, after I do the export I notice that the resultant png's do not have very
good resolution (I am asumming this is because they are not tif's).
Is there a "best" way to do what I want to accomplish?
Make a aerial base dwg file that I will have good images attached to it at
the correct coordinate system.
Other dwg files will xref the aerial base dwg.
I have tiff and tfw files.
Thank you,
John
news:6389208@discussion.autodesk.com...
worked.
-thanks
John
Murph
Thanks-
John
C3D 2010
3G RAM
XP PRO, SP2
Raster Design.
Matthew Anderson, PE
> John hi,
> not recomended.
> Arad
> Thanks-
Rail Community
